OpenStreetMap tile server
If you use OpenStreetMap as the geographic background for your smart map, you need to specify a tile server. You can specify a local tile server, for example if your organization has its own maps for areas such as airports or harbors, or you can use a commercial tile server.
Note
To use a local tile server, you do not need internet access.
The tile server address can be specified in two ways:
In XProtect Management Client - you set the tile server address on the Smart Client profiles. The server address applies to all XProtect Smart Client users assigned to the Smart Client profiles
In XProtect Smart Client - you set the tile server address in the Settings dialog. The server address applies only to that installation
