XProtect OnGuard Integration (XPALeS2)
Applying secure communications between XProtect and the XProtect OnGuard Integration Service
Versionv5.0
LanguageEnglish
In versions 4.2 and higher of the XProtect OnGuard Integration, there is a tool built into the XProtect OnGuard Integration Service to help users manage certificates. This process shows the steps required to generate, distribute, and configure the solution to secure communications between XProtect and the XProtect OnGuard Integration Service.
Important
The process included below is for self-signed certificates. If you are using a third party certificate, from a commercial certificate provider, please skip ahead to step number ten below. Refer to the Certificates guide for Milestone XProtect products for any questions on dealing with certificates.Certificates guide for Milestone XProtect products
  1. On a server with restricted access, open PowerShell as an administrator and run the script in Appendix A, to create a CA certificate.
  2. By default the script places the new root certificate in the C:\ file location. Move the certificate to the XProtect server.
  3. On the XProtect server right-click the certificate and select Install Certificate to begin the certificate installation wizard.
  4. Choose to place the certificate in the Store Location of the Local Machine.
  5. Browse and import the certificate in to the Trusted Root Certification Authorities folder.
  6. Complete the wizard.
  7. Go back to the server with restricted access where you generated the root certificate, open PowerShell and enter the script in Appendix B, to generate a new client certificate to install on the server hosting the XProtect OnGuard Integration Service.
  8. The script requires input: the DNS name of the server hosting the XProtect OnGuard Integration Service, the IP address of the server, and a certificate password of your own choosing - enter this information and complete the script.
  9. By default the script generates the certificate at the C:\ file location. Copy the file and move it to the server hosting the XProtect OnGuard Integration Service.
  10. Go to the server hosting the XProtect OnGuard Integration Service and run the certificates snap-in for the local machine. Right-click the Certificate store within the Personal folder and choose to Import a new certificate.
  11. Import the certificate into the store of the local machine. Choose the certificate file that you copied to the local server. Enter the password chosen during the script. Browse to the personal folder of the certificate store to choose that as the location for the certificate. Complete the import wizard
  12. Open the XProtect OnGuard Integration Service service tray icon and choose the certificate to use. It should match the hostname of the OnGuard server. The service restarts once the configuration is saved.
  13. Now apply encryption for the OnGuard XProtect Access instance in the XProtect Management Client. There are three options to use for secured communication for the integration. This process enables use of XProtect Access Service - SSL Certificate Validation, option A below.
