XProtect OnGuard Integration (XPALeS2)
Applying secure communications between the XProtect OnGuard Integration Service and OpenAccess
Versionv5.0
LanguageEnglish
In versions 4.2 and higher of XProtect OnGuard Integration, encrypted communication is fully supported. This process shows the steps required to extract and distribute the required certificates and configure the solution to enable secure communications between the XProtect OnGuard Integration Service and OpenAccess.
Important
The process below isn't needed when the XProtect OnGuard Integration Service runs on the OnGuard server that hosts the OpenAccess service. In integrated systems where the XProtect OnGuard Integration Service and the OpenAccess service are co-located encrypted communication can be enabled with no extra configuration.
  1. Go to the OpenAccess server, open PowerShell and run the following script to extract the CA certificate.
    $cert = Get-ChildItem 'Cert:\LocalMachine\LS Certificate Store' |`
    Where-Object{$_.Subject -like "*cn=$ENV:COMPUTERNAME*"}
    if ($cert) {$match = Select-String "CN=(.*?),"`
    -InputObject $cert.Issuer
    $issuer = $match.Matches.groups[1].Value
    $RootCert = Get-ChildItem 'Cert:\LocalMachine\Root'`
    |Where-Object{$_.Subject -like "CN=$issuer*"}
    if ($RootCert) {Export-Certificate -Cert $RootCert -FilePath ".\LenelCert.cer"}`
    else{write-host "Could not find $Issuer Certificate." -foregroundcolor Red}}`
    else{write-host "Could not find $env:Computername Certificate in LS Certificate Store."`
  2. By default the script exports the extracted root certificate to the current directory. Copy the certificate and move it to the XProtect OnGuard Integration Service server.
  3. On the XProtect OnGuard Integration Service host server, right-click the certificate and select Install Certificate to begin the certificate installation wizard.
  4. Choose to place the certificate in the Store Location of the Local Machine.
  5. Browse and import the certificate in to the Trusted Root Certification Authorities folder.
  6. Complete the wizard.
  7. Now apply encryption for the XProtect OnGuard Integration instance in the XProtect Management Client. This process enables use of OpenAccess- SSL Certificate Validation, option B below.
