XProtect Mobile client
Connection settings for a mobile server
Version2025r3
LanguageEnglish
When you add a mobile server to your XProtect Mobile app manually, you must configure a list of settings.
Settings on the Add servers screen
Setting
Description
Server name
The name of the server.
The name displays in the list of servers on your device and can be anything you want.
Address
The address of the computer where the XProtect Mobile server is running. The server address can be an IP address or a host name.
https:// or
http://
The type of connection that you will use to connect the XProtect Mobile client to the mobile server. By default, the HTTPS connection is selected.
Important
If you select the HTTP connection type, you must ensure that the mobile server also uses an HTTP connection. Otherwise, the XProtect Mobile app and the server cannot communicate.
Port number
The port number that the XProtect Mobile client uses to communicate with the server. For HTTP connections, the default port is 8081. For HTTPS connections, the default port is 8082.
Important
If you edit the port number, you must also edit the corresponding port number on the mobile server side. Otherwise, the XProtect Mobile app and the server cannot communicate.
Continue login
Go to the Login screen.
Save and log in later
Save the mobile server details and log in later.
Note
If you use an MDM functionality on your mobile device, the mobile server details will be entered automatically.
Settings on the Login screen
Setting
Description
Windows user
Basic user
Your login authentication type. Select whether you log in as a Windows user or as a basic user.
User name
A mandatory login credential.
Password
Note
The user name and password can be based on either basic users set up in Management Client or on Windows users. Windows user credentials are specific to a machine or a domain.
Remember me
Indicate whether you want to remember your user name and password for the next time you connect to an already added server. By default, the setting is enabled.
Log in
Log in to the XProtect Mobile client.
Change password
As a basic user, you can change your password whenever you want to (see Log in to the XProtect Mobile app).
Log in with [Name of an external IDP]
If your system administrator has configured a login with an external IDP, use this option to log in to the XProtect Mobile client. For more information, see
External IDP and XProtect Mobile client.
