XProtect Mobile client
External IDP and XProtect Mobile client
Version2025r3
LanguageEnglish
XProtect Mobile client supports login with an external IDP.
You can log in to the XProtect Mobile client via an external IDP with XProtect 2022 R3 and later.
Note
To log in with an external IDP to the XProtect Mobile client, you must use an HTTPS connection.
For more information, see the topic about the login with an external IDP in the administrator manual about the XProtect VMS.
