XProtect Management Server Failover
The failover web console
Version2026 R2
LanguageEnglish
Use the failover web console to manage the failover cluster. You can access the failover web console from any computer that can connect to Node 1 and Node 2.
How you open the failover web console depends on the computer:
  • On Node 1 and Node 2, double-click the icon of the XProtect Management Server Failover web console on your desktop.
  • On all other computers, type the URL of the failover web console in your browser: http://[computername.domainname]:9010 or https://[computername.domainname]:9453.
    [computername.domainname] is the FQDN of either Node 1 or Node 2.
  • You can view the failover web console from your Android phone using this address https://[computername.domainname]:9453
    Tip
    You can install the console as a Progressive Web App (PWA). In Chrome, tap the three-dot menu and select Add to Home screen.
To log in to the failover web console, you must authenticate with the user name admin and the password you set during the configuration of the failover cluster. If you do not remember your password, see Change the password for authentication.
From the failover web console, you can, for example:
Browser requirements
To view the failover cluster you must have:
  • A Microsoft Edge, Firefox, or Chrome browser
  • Network access to the cluster nodes with the necessary access permissions
  • Configure your network, firewall, and proxies to allow access to the cluster nodes.
