XProtect Management Server Failover
Uninstall XProtect Management Server Failover
Version2026 R2
LanguageEnglish
Important
Before you uninstall XProtect Management Server Failover, you must remove the failover management server configuration from both nodes.
  1. Open the Windows Control Panel. Then double-click Add or remove programs and select Milestone.
  2. Select Modify to launch the Milestone XProtect VMS wizard.
  3. On the Uninstall or change Milestone XProtect VMS components page, select Change one or more Milestone XProtect VMS components. Select Continue.
  4. Clear the check box for the XProtect Management Server Failover component and select Continue.
  5. When the installation completes, a list shows the components that you have installed on the computer.
