XProtect Management Server Failover
Required and optional XProtect VMS components
Version2026 R2
LanguageEnglish
Depending on the size of your VMS installation and resources, you can configure XProtect Management Server Failover in different ways. You can install the following system components on Node 1 and Node 2 in a domain or workgroup environment:
On the failover cluster nodes, you must install:
  • XProtect management server
  • XProtect event server
  • OpenTelemetry bundle
Additionally, you can install the following system components:
