XProtect Management Server Failover
Prerequisites for SQL Server with data replication
Version2026 R2
LanguageEnglish
When you install SQL Server on the nodes, XProtect Management Server Failover replicates the contents of the SQL Server databases and triggers failover if the SQL Server instance fails.
To use data replication with XProtect Management Server Failover, the SQL Server installations must be identical on both nodes. You can see a lits supported SQL Server editions for your VMS product at https://www.milestonesys.com/systemrequirements/.
Also, consider the following prerequisites:
