XProtect Management Server Failover
Prerequisites for SQL Server without data replication
Version2026 R2
LanguageEnglish
You can set up a failover cluster with an external SQL Server instance not running on the nodes. With this configuration, XProtect Management Server Failover does not monitor the SQL Server databases.
Note
The failover server configuration with external SQL Server does not work in a workgroup environment.
