Validate an XProtect installation file
Version2026 R2
LanguageEnglish
Before you install XProtect, verify that the installation file is authentic and has not been altered. Validation confirms that your copy of the file matches the file Milestone published, and that Milestone signed it.
Before you begin
  1. Log in to the Milestone Download page with your Milestone account and, under XProtect VMS Products, choose the 2026 R2 version.
  2. Download the installation file (.iso) and the checksum file for the installation file. They are two separate files.
  3. Confirm that you can run Windows PowerShell on the computer where the file is stored.
Note: Download the checksum file only from the Milestone Download page. Do not use a checksum from any other source, such as one sent to you by email. A modified file can be accompanied by a matching modified checksum.
Compare the file checksum
  1. Open Windows PowerShell.
  2. Run the following command, replacing the path with the location of your file: Get-FileHash -Algorithm SHA512 "<path to the installation file>".
  3. Compare the value in the Hash field with the checksum published by Milestone.
Note: The two values must match. Differences in letter case or spacing do not matter. Any other difference means the file is not the file Milestone published. Do not install it. Instead, delete the file, download the installation file and the checksum again from the download page, and repeat the comparison. If the values still do not match, contact Milestone Support.
Note: If you cannot use PowerShell, run this command in Command Prompt instead: certutil -hashfile "<path to the installation file>" SHA512
Verify the digital signature
  1. Double-click the .iso file to mount it as a drive.
  2. In the mounted drive, right-click the installer (.exe) file and select Properties.
  3. Select the Digital Signatures tab.
  4. Select the signature in the list, and then select Details.
  5. Verify that the dialog shows This digital signature is OK and that the signer is Milestone Systems A/S. To check the issuer, select View Certificate and verify that the certificate is issued by GlobalSign GCC R45 EV CodeSigning CA 2020.
Note: To check the signature from PowerShell instead, run Get-AuthenticodeSignature "<path to the installer (.exe) file>". The Status field must show Valid.
Note: If the file has no signature, the signature is not valid, or the signer is not Milestone, do not install the file.
Verify the publisher
  1. In the mounted drive, run the installer (.exe) file.
  2. In the Windows User Account Control prompt, verify that the publisher is Milestone Systems A/S signed by GlobalSign GCC R45 EV CodeSigning CA 2020.
Note: If the prompt shows an unknown publisher, cancel and do not install the file. Do not dismiss or bypass Windows security warnings without reviewing them.
Result
The installation file matches the file Milestone published, and Milestone signed it. You can continue with the installation.
What to do next
  • Install new XProtect components
  • Troubleshooting: installation file validation fails
