Requirements for offline installation
Version2026 R2
LanguageEnglish
If you install the system on a server that is offline, you need the following:
  • The Milestone XProtect VMS Products [Release_Version] System Installer.exe file
  • The software license file (SLC) for your XProtect system
  • OS installation media including the required .NET version https://www.milestonesys.com/systemrequirements/
