Managing server logs
Version2026 R2
LanguageEnglish
Server logs help you monitor system activity, user actions, and rule-triggered events in XProtect. The following types of server logs are available:
Log type
What is logged?
System logs
System activity, events, and errors
Audit logs
User activity
Rule-triggered logs
Rule-generated log entries. See Actions and stop actions for more information.
You can view server logs in XProtect Management Client under Server Logs.
For information about logs used for troubleshooting, see Debug logs.
Search and filter logs
You can search and filter logs to find specific events or activities. The available filters include:
  • General filters for field values, words, phrases, and stream information
  • Searches across multiple fields
  • Time-based filters
  • Day and week range filters
  • Stream filters
  • Word, phrase, and prefix filters
You can combine filters to create more precise queries.
For detailed filter syntax and examples, see the VictoriaLogs documentation: LogsQL documentation
Export logs
Export logs if you need to retain log entries beyond the configured retention period or share them for analysis and auditing. Logs are exported as JSON files.
To export logs:
  1. Run a query with the required filters.
  2. Select the JSON tab.
The exported file is saved to your default download location.
Warning
For CAPSS-compliant systems, Milestone recommends storing exported logs on a secure write-once medium or applying digital signatures using Windows tools or third-party solutions.
