Debug logs
Version2026 R2
LanguageEnglish
Debug logs are used to identify defects and flaws in the system.
The following are the locations of the log files in the XProtect installation:
  • C:\ProgramData\Milestone\IDP\Logs
    Note
    This is accessible only to IIS user and administrators. If the IIS user is changed, these permissions must be updated.
  • C:\ProgramData\Milestone\MIPSDK
  • C:\ProgramData\Milestone\XProtect Data Collector Server\Logs
  • C:\ProgramData\Milestone\XProtect Event Server\Logs
  • C:\ProgramData\Milestone\XProtect Log Server
  • C:\ProgramData\Milestone\XProtect Management Server\Logs
  • C:\ProgramData\Milestone\XProtect Mobile Server\Logs
  • C:\ProgramData\Milestone\XProtect Recording Server\Logs
  • C:\ProgramData\Milestone\XProtect Report Web Server\Logs
