Application pools
Version2026 R2
LanguageEnglish
The VMS contains standard application pools such as.NET v4.5, .NET v4.5 Classic and the DefaultAppPool. The application pools that are available on your system appear in the Internet Information Services (IIS) Manager. In addition to the standard application pools mentioned above, a set of VideoOS application pools are delivered with the Milestone XProtect VMS.
Application pools in Milestone XProtect
In the table below you can get an overview of the VideoOS application pools that are delivered with Milestone XProtect.
Name
Identity
Purpose
.NET v4.5
ApplicationPoolId
Standard IIS feature
.NET v4.5 Classic
ApplicationPoolId
DefaultAppPool
ApplicationPoolId
VideoOS ApiGateway
NetworkService
Hosts the XProtect API Gateway which is the future public API and gateway to the VMS.
VideoOS Classic
NetworkService
Hosts legacy components such as the local help mainly to comply with backwards compatibility.
VideoOS IDP
NetworkService
Hosts the Identity Provider API. The Identity Provider creates, maintains, and manages identity information for basic users and provides authentication and registration services to relying applications or services.
VideoOS IM
NetworkService
Hosts the XProtect Incident Manager API. The XProtect Incident Manager documents incidents and combine them with sequence evidence (video and, potentially, audio) from their XProtect VMS.
VideoOS Management Server
NetworkService
Hosts the Configuration API, server component APIs and other Management Server services, and manages user authorization.
VideoOS ReportServer
NetworkService
Hosts the web application that is responsible for collecting and creating reports for alarms and events.
VideoOS ShareService
NetworkService
Hosts the service that facilitates bookmarks and live video sharing between the users of XProtect Mobile client.
Working with application pools
From the Application Pools page in the Internet Information Services (IIS) window you can add application pools or set application pool defaults and you can view the applications hosted by each application pool.
Open the Application Pools page
  1. From the Windows Start menu, open Internet Information Servces (IIS) Manager.
  2. In the Connections pane, click the name of your environment, and then click Application Pools.
  3. Under Actions, click Add Application Pool or Set Application Pool Defaults to perform any of these tasks.
  4. Select an application pool on the Application Pools page to display further options under Actions for each application pool.
