Ports used by the system
Last Updated: 41 minute read
Version2026 R2
LanguageEnglish
XProtect components communicate over the network by using the ports and protocols described in this topic. Use this information when configuring firewalls and network access between XProtect components, clients, integrations, hardware devices, and external services.
Enable only the communication required by the components, features, and integrations in your deployment. The tables also include local communication between processes on the same computer. Local communication does not normally require a cross-host firewall rule.
Port numbers are defaults unless otherwise stated. Some ports can be changed through the product configuration.
You can look up communication in two ways:
  • Communication by listener identifies the service that accepts a connection, the systems that initiate the connection, and the transport and application protocols used.
  • View by component computer summarizes the inbound, outbound, and local communication associated with a specific XProtect component computer.
The communication required in a deployment depends on the installed components, enabled features, configured integrations, and deployed hardware devices.
How to read the tables
  • Firewall use identifies when the communication is required and whether a cross-host firewall rule is relevant.
  • Local only means that the connection is restricted to processes on the same computer and does not require a cross-host firewall rule.
  • Intended for same-computer communication means that the product uses the connection between services on the same computer, but the listener might not be restricted to the loopback interface. Do not allow cross-host access when the table instructs you to block it.
  • Configured means that the deployment configuration determines the actual scheme, address, or port.
Installing certificates does not automatically change every communication channel to HTTPS or TLS. Follow the protocol behavior specified for each listener.
The listener view is organized by the computer on which a service accepts connections. To determine which inbound firewall rules are required on a computer, consider all XProtect services installed on that computer.
Do not open every port listed in this topic. Open a port only when the corresponding component or feature is installed, enabled, and required in the deployment.
Listener table columns
  • Initiator is the client, component, process, integration, or external system that opens the connection.
  • Listener is the service that accepts the connection.
  • Without certificates describes the application protocol used when certificate-based transport security is not enabled for that interface.
  • With certificates describes the application protocol used when certificate-based transport security is enabled for that interface.
  • Purpose describes the function provided by the listener.
The management server computer hosts the Management Server web services, Identity Provider, OpenTelemetry Collector, VictoriaLogs, and optional IIS-hosted services such as XProtect Incident Manager . By default, the computer also hosts the API Gateway.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
80, default
TCP
XProtect clients, XProtect server components, and integrations
Management Server web services, Identity Provider, API Gateway, and optional IIS-hosted services
HTTP
HTTP remains available for supported HTTP endpoints
Cross-host. Allow from clients, components, and integrations that require HTTP-based access to Management Server services or Identity Provider services. Restrict access to trusted management networks.
Provides discovery, authentication, registration, configuration, monitoring data, state updates, management server APIs, and optional IIS-hosted services, including XProtect Incident Manager .
443, default
TCP
Not applicable
HTTPS
Cross-host. Allow from clients, components, and integrations that require access to Management Server services or Identity Provider services over HTTPS.
Provides authentication, registration, configuration, monitoring data, state updates, management server APIs, and optional IIS-hosted services, including XProtect Incident Manager .
4318
TCP
XProtect server components and the API Gateway installed on the management server computer
OTLP/HTTP
OTLP/HTTP
Intended for same-computer communication. Do not allow cross-host access through the firewall.
Receives logs from XProtect server components and the API Gateway installed on the management server computer.
6473
TCP
Management Server Manager tray process
Management Server
Loopback gRPC
Loopback gRPC
Local only. No cross-host firewall rule is required.
Provides local Management Server status and service management.
8080
TCP
Local management server process
Management Server internal service
Loopback HTTP/WCF
Loopback HTTP/WCF
Supports communication between internal management server processes.
9000
TCP
Recording server, including an active failover recording server
Management Server ’s Recording Server Web API
HTTP
HTTPS
Cross-host. Required for communication between recording servers and the management server. Allow from recording server computers.
Recording server registration, status and log transfer, configuration exchange, and command responses.
9428
TCP
OpenTelemetry Collector and API Gateway installed on the management server computer
VictoriaLogs system-log service
HTTP OTLP ingestion and HTTP query access
Stores and provides query access to system logs.
9429
TCP
VictoriaLogs audit-log service
Stores and provides query access to audit logs.
9430
TCP
VictoriaLogs rule-log service
Stores and provides query access to rule logs.
12974
TCP
Local Windows SNMP extension bridge
Management Server
Loopback .NET Remoting
Local only. Used when the SNMP extension is enabled. No cross-host firewall rule is required.
Connects the local Windows SNMP extension bridge to the management server.
Management Server web-service ports
The configured Management Server URI determines the scheme, host, and port used by XProtect clients, server components, and integrations. Ports 80 and 443 are the defaults.
The table does not enumerate every system that can use the Management Server web services. Installed components, enabled features, and configured integrations determine which systems require access.
Installing certificates does not restrict port 80 to discovery or other well-known endpoints only. Supported HTTP endpoints remain available according to their endpoint configuration. Endpoints configured for transport security use HTTPS.
Caution
Restrict access to Management Server port 80 to trusted management networks.
Logs
The OpenTelemetry Collector and VictoriaLogs are used for log processing and storage on the management server computer.
Ports 4318 and 9428 through 9430 are used for communication between logging services on the management server computer. Do not allow cross-host access to these local listeners through the firewall.
XProtect components on other computers submit and retrieve logs through the API Gateway installed on the management server computer.
XProtect can also forward logs to a configured external monitoring or logging solution by using OTLP. The standard destination port is 4317 for OTLP over gRPC or 4318 for OTLP over HTTP. Allow outbound traffic only to the endpoint and port required by the configured monitoring solution.
The recording server accepts connections from XProtect clients, server components, integrations, and Failover Server services. Some listeners are optional or used only when a corresponding feature, device driver, or failover function is enabled.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
5210
TCP
Recording server
Recording Server media database service
Proprietary TCP protocol with authentication
Proprietary TCP protocol with authentication over TLS
Cross-host. Allow between applicable recording server and failover recording server computers when access to recorded media on another server is required.
Provides access to recorded media that remains on the Recording Server after a device has been moved to another Recording Server .
5432, configurable
TCP
Configured driver or device
Recording Server driver-alert listener
Plain TCP without authorization
Disabled by default. Allow only from devices or drivers that require this listener. Restrict permitted source hosts.
Receives legacy driver alerts and events.
7563
TCP
XProtect clients, XProtect server components, interconnected sites, and integrations that retrieve data from the recording server
Recording Server media and command services
Custom HTTP/Image Server and SOAP over TCP
The same services over TLS
Cross-host. Allow from clients, components, sites, and integrations that retrieve data or use Recording Server services.
Provides video, audio, metadata, JPEG retrieval, PTZ, speaker audio, events and status, outputs, and recording commands.
8966
TCP
Recording Server Manager tray process
Recording Server
Loopback gRPC
Loopback gRPC
Provides local Recording Server status and service management.
9001
TCP
 Management server
HTTP
HTTPS
Cross-host. Allow from the management server computer.
Provides management server -to- recording server commands, configuration, and status communication.
11000
TCP
Recording Server failover-response service
Custom framed TCP
TLS
Cross-host. Allow from applicable failover server computers when failover is configured.
Supports health polling and failover-control messages.
12975
TCP
Recording Server
Connects the local Windows SNMP extension bridge to the recording server.
65101, incremented if occupied
UDP
Local driver process
Recording Server driver-event listener
UDP
UDP
Receives local event notifications from device drivers.
A failover recording server computer has two services installed:
  • The Failover Server service, which monitors the relevant recording servers and manages failover.
  • The Failover Recording Server service, which enables the computer to take over recording server functions.
The listener table includes communication for both services.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
5210
TCP
Recording server
Failover Recording Server media database service
Cross-host. Allow from the applicable recording server when access to recorded media stored on the failover recording server is required.
Provides access to recorded media that was stored on the failover recording server during a failover event.
7563
TCP
XProtect clients, XProtect server components, interconnected sites, and integrations that retrieve data from the active failover recording server
Active Failover Recording Server media and command services
Cross-host. Used while the failover recording server is active. Allow from systems that retrieve media or use Recording Server services.
8844
UDP
Peer Failover Server services
Plain UDP
Plain UDP
Cross-host. Allow between failover server computers in the same failover group. Each Failover Server service both sends and listens on this port.
Exchanges peer and group status information between Failover Server services.
8966
TCP
Failover Recording Server Manager tray process
Loopback gRPC
Loopback gRPC
Provides local Failover Recording Server status and service management.
8967
TCP
Failover Server Manager tray process
Loopback gRPC
Loopback gRPC
Provides local Failover Server service status and service management.
8990
TCP
Management server
Failover Server service status API
HTTP
HTTPS
Provides Failover Server service status information to the management server.
9001
TCP
Management server
Active Failover Recording Server Web API
HTTP
HTTPS
Cross-host. Used while the failover recording server is active. Allow from the management server computer.
11000
TCP
Failover Recording Server failover-response service
Custom framed TCP
TLS
Local only. The Failover Server service and Failover Recording Server service are installed on the same failover recording server computer. No cross-host firewall rule is required.
The event server provides services for events, alarms, maps, messaging, and supported integrations.
Generic Events and Analytics Events listeners are disabled by default. Enable only the listeners and data sources required by the deployment. These interfaces do not automatically become encrypted when certificates are installed.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
1234, configurable
TCP and/or UDP
External Generic Events sender
Event Server Generic Events listener
TCP and/or UDP
TCP and/or UDP
Disabled by default. Allow only from systems that send Generic Events. The listener does not use HTTPS, authentication, or authorization.
Receives Compatible Generic Events from external systems or devices.
1235, configurable
TCP
TCP
TCP
Receives International Generic Events from external systems or devices.
9090, configurable
TCP
External Analytics Events sender
Event Server Analytics Events listener
TCP using raw XML or an HTTP-like POST
Disabled by default. Allow only from configured Analytics Events sources. The security option is a source-host allow list, not TLS.
Receives Analytics Events from external systems or devices.
22331
TCP
XProtect clients and integrations
Event Server WCF services
HTTP WCF/SOAP
HTTPS WCF/SOAP
Cross-host. Allow from clients and integrations that require Event Server WCF services.
Provides configuration, alarms, maps, status, actions, and related Event Server services.
22332
TCP
API Gateway, Management Client , and supported direct API clients
Event Server REST and WebSocket services
HTTP and WS
HTTPS and WSS
Cross-host. Allow from API Gateway and clients that use the supported REST or WebSocket interfaces.
Provides event and state subscriptions, Events REST, Alarms REST, and WebSocket Messaging APIs.
22333
TCP
MIP plug-ins and applications
Event Server legacy MIP message service
Net.TCP with SecurityMode.None
Listener is not used; secure MIP communication uses HTTPS on port 22331
Used only without encryption. Allow from applicable MIP applications.
Provides legacy MIP filter, registration, transmission, reception, and messaging functions.
Additional administrator-configured Generic Events ports are not listed in this overview. If you configure an additional Generic Events data source, configure the corresponding firewall access as described in the Generic Events documentation.
API Gateway is installed on the management server computer by default and can also be installed on separate computers. A deployment can contain multiple API Gateway instances.
Only the API Gateway installed on the management server computer provides log submission and retrieval.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
Configured IIS HTTP port, normally 80
TCP
API clients, XProtect clients, XProtect server components, and integrations
API Gateway through IIS
HTTP and WS
Not applicable
Cross-host. Allow from systems that require the API Gateway over HTTP. Restrict access according to the deployment security policy.
Provides Gateway REST, WebSocket, WebRTC, Management proxy, and Event proxy services. The API Gateway installed on the management server computer also provides log submission and retrieval.
Configured IIS HTTPS port, normally 443
TCP
Not applicable
HTTPS and WSS
Cross-host. Allow from systems that require the API Gateway over HTTPS.
Provides transport-secured Gateway REST, WebSocket, WebRTC, Management proxy, and Event proxy services. The API Gateway installed on the management server computer also provides log submission and retrieval.
The configured IIS bindings determine the actual HTTP and HTTPS ports used by API Gateway. Open only the binding required by the deployment and restrict access to trusted clients, components, and integrations.
The management server initiates connections to the Data Collector on each monitored computer. The Data Collector separately initiates communication to the configured Management Server web-service endpoint, as shown in the component-computer view.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
7609
TCP
Management server
gRPC over HTTP
gRPC over HTTPS
Cross-host. Allow from the management server computer to each monitored computer.
Provides live performance counters and monitoring information for System Monitor.
Mobile Server provides separate, independently configurable HTTP and HTTPS listeners for XProtect Mobile client, XProtect Web Client, and supported Mobile Server administration functions.
Video Push uses a separate configurable listener for communication from the recording server. The Video Push listener is disabled by default.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
8081, configurable
TCP
XProtect Mobile client, XProtect Web Client, Management Client
Mobile Server
HTTP
Remains HTTP if the listener is enabled
Cross-host. Allow from clients that use the unsecured Mobile Server interface.
Provides client commands and video and audio delivery.
8082, configurable
TCP
Mobile Server
Not applicable
HTTPS
Cross-host. Allow from clients that use the secured Mobile Server interface.
Provides transport-secured client commands and video and audio delivery.
40001 + channel index, configurable
TCP
Recording server
Mobile Server Video Push media-provider listener
TCP with HTTP-like MIP media-provider framing
Disabled by default. Allow from applicable recording server computers when Video Push is enabled.
Provides the recording server with access to a Video Push virtual-camera feed.
XProtect LPR Server is installed as part of an XProtect LPR deployment. The event server requires the XProtect LPR plug-in to communicate with the LPR Server.
The LPR Server listener port is configurable. If certificate-based event server communication is enabled, configure the LPR components to use the secured interface.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
22334, configurable
TCP
Event server LPR plug-in, supported administration clients, and the local LPR Server Manager tray icon
LPR Server WCF service
HTTP WCF
HTTPS WCF
Cross-host. Allow from the event server computer and supported administration computers when XProtect LPR is installed.
Provides LPR Server status, recognized-license-plate results, commands, configuration, and JPEG-analysis requests.
Milestone Open Network Bridge provides ONVIF and RTSP interfaces for supported third-party clients.
WS-Discovery is optional and disabled by default. Media can be transported over the RTSP TCP connection or by using negotiated RTP and RTCP UDP ports, as shown in the component-computer view.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
554, configurable
TCP
ONVIF and RTSP clients
Milestone Open Network Bridge RTSP service
RTSP over TCP
RTSP over TCP
Cross-host. Allow from ONVIF or RTSP clients that retrieve media through the bridge.
Provides RTSP session control. RTP and RTCP can be interleaved over the RTSP TCP connection.
580, configurable
TCP
ONVIF clients
Milestone Open Network Bridge ONVIF service
HTTP/SOAP
HTTPS/SOAP
Cross-host. Allow from ONVIF clients that require access to the bridge.
Provides ONVIF authentication, device and media services, PTZ operations, events, searches, replay control, and video-stream configuration.
3702
UDP
WS-Discovery client
Milestone Open Network Bridge discovery service
WS-Discovery
WS-Discovery
Cross-host, optional, and disabled by default. Allow only when ONVIF WS-Discovery is enabled.
Enables ONVIF clients to discover Milestone Open Network Bridge .
XProtect Smart Client normally initiates connections to XProtect server components. When XProtect Smart Client is configured as a Matrix recipient, the XProtect Smart Client computer also accepts inbound Matrix commands from the management server.
The Matrix recipient listener is disabled by default and uses a configurable TCP port.
Port
Transport
Initiator
Listener
With certificates
Firewall use
Purpose
12345 by default, configurable
TCP
Management server
XProtect Smart Client Matrix recipient
Plain TCP
Plain TCP
Disabled by default. Allow from the management server computer when the XProtect Smart Client computer is configured as a Matrix recipient.
Receives Matrix connect, disconnect, and view commands.
The component-computer view summarizes the inbound, outbound, and local communication associated with each XProtect component computer or client.
Use this view when configuring firewall rules for a specific computer. A server component can both accept connections and initiate connections to other XProtect components, external services, integrations, or hardware devices.
For application protocol and certificate behavior, follow the link in the Details column to the corresponding entry under Communication by listener . A dash in the Details column indicates that the peer is an external or configuration-dependent destination for which this topic does not define the listener.
Open only the communication required by installed components, enabled features, configured integrations, and deployment-specific destinations.
Component-computer table columns
  • Direction identifies whether the connection is inbound to, outbound from, or local to the component computer.
  • Peer component or system identifies the computer, client, integration, hardware device, or external system at the other end of the connection.
  • Peer service identifies the service or interface at the other end of the connection.
  • Details links to the corresponding listener entry when that listener is documented in this topic. A dash indicates an external or configuration-dependent destination for which this topic does not define the listener.
  • Purpose describes why the component computer uses the connection.
The management server computer hosts the Management Server services, Identity Provider, OpenTelemetry Collector, VictoriaLogs, and optional IIS-hosted services such as XProtect Incident Manager . By default, the computer also hosts an API Gateway.
API Gateway is documented in a separate component view because it can also be installed on another computer. The management server computer view includes the OpenTelemetry Collector and VictoriaLogs listeners hosted on the management server computer. The API Gateway component view shows the corresponding local communication initiated by the API Gateway installed on that computer.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
80/TCP, default
Allow from systems that require HTTP-based Management Server services. Restrict access to trusted management networks.
Management server computer listeners
Inbound
443/TCP, default
Allow from systems that require Management Server or Identity Provider services over HTTPS.
Inbound
9000/TCP
Recording servers, including active failover recording servers
Management server's recording server Web API
Outbound
25/TCP by default, configurable
Configured SMTP server
SMTP server
Allow from the management server computer to the configured SMTP server when email notifications are configured.
Sends email notifications. TLS use depends on the SMTP configuration.
Outbound
443/TCP
www.milestonesys.com
License Management service at /OnlineActivation/LicenseManagementService.asmx
Allow when online or automatic license activation is used.
Activates licenses.
Outbound
Configured SQL endpoint/TCP, conventionally 1433
Configured SQL Server
SQL Server
Allow from the management server computer to the configured SQL Server endpoint.
Stores and retrieves product configuration and other management server database information. The configured SQL instance and connection string determine the actual destination and port.
Outbound
4317/TCP, or the configured destination port
Administrator-configured external monitoring or logging solution
OTLP over gRPC endpoint
Required only when an administrator configures the OpenTelemetry Collector to forward logs to an external OTLP over gRPC endpoint. Allow only to the configured destination address and port.
The OpenTelemetry Collector forwards logs to the configured external monitoring or logging solution by using OTLP over gRPC.
Outbound
4318/TCP, or the configured destination port
OTLP over HTTP endpoint
Required only when an administrator configures the OpenTelemetry Collector to forward logs to an external OTLP over HTTP endpoint. Allow only to the configured destination address and port.
The OpenTelemetry Collector forwards logs to the configured external monitoring or logging solution by using OTLP over HTTP.
Outbound
7609/TCP
Each monitored computer
Data Collector
Allow from the management server computer to each monitored computer. Required for System Monitor data collection.
Queries live performance counters and monitoring information.
Data Collector listeners
Outbound
8990/TCP
Failover server computer
Allow from the management server computer to each failover server computer when failover server is installed.
Monitors the status of the Failover Server service.
Failover recording server computer listeners
Outbound
9001/TCP
Recording server computer
Recording server Web API
Allow from the management server computer to each managed recording server.
Sends commands and exchanges configuration and status information.
Recording server computer listeners
Outbound
12345/TCP by default, configurable
Configured Matrix recipient
Matrix recipient, typically XProtect Smart Client
Allow from the management server computer to configured Matrix recipients when Matrix is used.
Sends Matrix connect, disconnect, and view commands using plain TCP.
XProtect Smart Client computer listeners
Local
4318/TCP
Receives logs through OTLP/HTTP.
Local
6473/TCP
Management Server
Provides local management server status and service management.
Local
8080/TCP
Supports communication between internal manaement server processes.
Local
9428/TCP
Local
9429/TCP
Local
9430/TCP
Local
12974/TCP
Management Server
The recording server communicates with the management server, clients, Failover Server services, interconnected sites, Mobile Server, and deployed hardware devices.
Communication with cameras, NVRs, encoders, I/O devices, and other hardware devices depends on the device, driver, enabled functions, selected media transport, and device configuration. Allow only the ports and protocols required by the deployed hardware. For device-specific network requirements, consult the device manufacturer’s documentation.
For information about supported devices, drivers, firmware, and capabilities, see the Supported devices.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
5210/TCP
Recording server that requires access to the recorded media
Allow between applicable recording server computers where access to recorded media on another recording server is required.
Provides access to recorded media that remains on the recording server after a device has been moved to another recording server.
Inbound
5432/TCP, configurable
Disabled by default. Allow only from required and trusted source hosts.
Inbound
7563/TCP
Allow from systems that retrieve media or use supported Recording Server services.
Provides video, audio, metadata, commands, status, outputs, and recording operations.
Inbound
9001/TCP
Receives management server commands and exchanges configuration and status information.
Inbound
11000/TCP
Outbound
80 or 443/TCP, configured management server URI
Management Server web services and Identity Provider
Allow to the configured management server URI.
Supports authentication, discovery, registration, configuration, and Management Server services.
Outbound
5210/TCP
Recording server or failover recording server computer hosting the required media
Allow when the recording server requires access to recorded media stored on another recording server or failover recording server.
Accesses recorded media stored on another recording server or failover recording server.
Recording server computer listeners  / Failover recording server computer listeners
Outbound
7563/TCP, configured destination
Remote interconnected site
Remote Recording Server media and command service
Allow when XProtect Interconnect is configured.
Transfers supported media, events, status, and commands between interconnected sites.
Outbound
9000/TCP
Allow from the recording server computer to the management server computer.
Sends registration, status, logs, configuration responses, and command responses.
Outbound
40001 + channel index/TCP, configurable
Mobile Server computer
Disabled by default. Allow when Video Push is enabled.
Connects to the Mobile Server to provide a Video Push virtual-camera feed.
Mobile Server computer listeners
Outbound
Device-configured
Cameras, NVRs, encoders, I/O devices, and other hardware devices
Device services
Allow only the ports and protocols required by the deployed devices, drivers, and enabled device functions.
Supports device authentication, configuration, media, metadata, events, audio, PTZ, I/O, and other device functions.
Consult the device manufacturer’s documentation.
Local
8966/TCP
Recording Server
Provides local status and service management.
Local
12975/TCP
Recording Server
Local
65101/UDP, incremented if occupied
Receives event notifications from device drivers.
A failover recording server computer has the Failover Server service and the Failover Recording Server service installed.
The Failover Server service monitors the applicable recording servers and manages failover. The Failover Recording Server service enables the computer to take over recording server functions.
The table includes communication for both services. Device and media communication is used while the failover recording server has taken over recording server functions. Monitoring and coordination communication can remain active independently of a failover.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
5210/TCP
Allow when access to recorded media stored on the failover recording server is required.
Inbound
7563/TCP
Allow while the failover recording server is active from systems that retrieve media or use Recording Server services.
Inbound
8844/UDP
Peer failover server computers
Receives peer and group status information.
Inbound
8990/TCP
Provides Failover Server service status information.
Inbound
9001/TCP
Allow from the management server computer while the failover recording server is active.
Receives commands and exchanges configuration and status information.
Outbound
Configured management server URI/TCP, normally 80 or 443
Outbound
8844/UDP
Sends peer and group status information.
Outbound
9000/TCP
Allow from the active failover recording server to the management server computer.
Sends registration, status, logs, configuration responses, and command responses while active.
Outbound
11000/TCP
Recording server computers
Allow to each recording server monitored by the Failover Server service.
Polls recording server health and sends failover-control messages.
Outbound
Device-configured
Device services
Local
8966/TCP
Provides local Failover Recording Server service status and service management.
Local
8967/TCP
Local
11000/TCP
Supports health polling and failover-control messages between the local Failover Server service and Failover Recording Server service.
Event server communicates with XProtect clients, API Gateway, supported integrations, management server, SQL Server, optional XProtect LPR Server, and optional Milestone Customer Dashboard services.
Generic Events and Analytics Events connections are required only when the corresponding inputs are enabled and configured.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
1234/TCP and/or UDP, configurable
External Generic Events senders
Compatible Generic Events listener
Disabled by default. Allow only from configured Generic Events sources.
Event server computer listeners
Inbound
1235/TCP, configurable
International Generic Events listener
Inbound
9090/TCP, configurable
External Analytics Events senders
Receives Analytics Events.
Inbound
22331/TCP
Allow from clients and integrations that require Event Server services.
Provides configuration, alarms, maps, status, actions, and related services.
Inbound
22332/TCP
Allow from API Gateway and supported API clients.
Provides events, alarms, subscriptions, and WebSocket messaging APIs.
Inbound
22333/TCP
Legacy MIP message service
Used only without event server certificate encryption.
Provides legacy MIP messaging.
Outbound
Supports configuration, service discovery, state, authentication-related discovery, and registration.
Outbound
443/TCP
service.milestonesys.com
Milestone Customer Dashboard HTTPS service
Allow when Milestone Customer Dashboard communication is enabled and licensed.
Sends Milestone Customer Dashboard key, notification, status, error, and heartbeat information.
Outbound
SQL Server
Allow to the SQL endpoint specified in the connection configuration.
Stores and retrieves event server event, alarm, and configuration data.
Outbound
22334/TCP, configurable
LPR Server computer
Allow when XProtect LPR and the event server LPR plug-in are installed.
Retrieves recognized plates and status and sends supported LPR commands and configuration requests.
XProtect LPR Server computer listeners
API Gateway can be installed on the management server computer or on a separate computer. A deployment can contain multiple API Gateway instances.
Only the API Gateway installed on the management server computer provides log submission and retrieval. The local OpenTelemetry Collector and VictoriaLogs entries in this table apply only to that API Gateway.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
Configured IIS HTTP port/TCP, normally 80
Allow from systems that require HTTP access to API Gateway.
API Gateway computer listeners
Inbound
Configured IIS HTTPS port/TCP, normally 443
Allow from systems that require HTTPS access to API Gateway.
Outbound
Supports Management REST, discovery, Identity Provider, registration, permissions, and related proxied requests.
Outbound
22332/TCP
Allow to each event server used by API Gateway.
Proxies events, alarms, subscriptions, and WebSocket messaging requests.
Local
4318/TCP
OpenTelemetry Collector on the management server computer
Internal on the management server computer. Do not allow cross-host access through the firewall.
Sends API Gateway logs to the OpenTelemetry Collector using OTLP/HTTP.
Local
9428/TCP
VictoriaLogs on the management server computer
Queries system logs.
Local
9429/TCP
Queries audit logs.
Local
9430/TCP
Queries rule logs.
Data Collector accepts System Monitor requests from the management server and independently connects to the configured Management Server web-service endpoint to register and submit monitoring information.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
7609/TCP
Data Collector
Outbound
Supports service registration, machine properties, monitoring-data batches, state changes, and related management server communication.
Mobile Server acts as the system gateway for XProtect Mobile client and XProtect Web Client. It retrieves media from recording servers and communicates with optional Milestone-hosted services when the corresponding functions are enabled.
The administrator configures whether the Mobile Server HTTP listener, HTTPS listener, or both listeners are available.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
8081/TCP, configurable
Mobile Server HTTP service
Inbound
8082/TCP, configurable
Mobile Server HTTPS service
Inbound
Outbound
443/TCP
abs.milestonesys.com
Milestone address-book or Smart Connect service
Allow when the address-book or Smart Connect function is enabled.
Provides address-book or Smart Connect communication.
Outbound
443/TCP
push.milestonesys.com
Milestone push-notification service
Allow when mobile push notifications are enabled.
Sends mobile push-notification requests.
Outbound
Supports authentication, configuration, service registration, and discovery of registered service endpoints.
Outbound
Configured recording server URI/TCP, commonly 7563
Active Management server computer
Allow to the registered recording server addresses returned by the management server.
Retrieves video and audio and performs supported device and media operations.
Local
Not applicable
Mobile Server Manager tray process
Mobile Server service
Uses a named pipe. No TCP firewall rule is required.
Provides local Mobile Server status and service management.
XProtect LPR Server communicates with the management server and recording server and accepts requests from the event server LPR plug-in and supported administration clients.
Include these connections only when XProtect LPR is installed.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
Outbound
Supports authentication, configuration, service registration, and discovery of recording server addresses.
Outbound
Active recording server computer
Allow to the configured recording server URI.
Retrieves video for license-plate recognition processing.
XProtect Smart Client initiates connections to the management server, API Gateway, recording server, and event server according to the features used by the client.
When configured as a Matrix recipient, the XProtect Smart Client computer also accepts inbound Matrix commands from the management server. Milestone Map Service requires outbound HTTPS access when enabled for Smart Maps.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
Outbound
Configured HTTP or HTTPS port/TCP, normally 80 or 443
Management server computer, API Gateway computer
Management Server web services, Identity Provider, and API Gateway
Allow to the configured management server and API Gateway addresses.
Supports authentication, service discovery, configuration, management server APIs, optional XProtect Incident Manager functionality, and API Gateway services.
Management server computer listeners  / API Gateway computer listeners
Outbound
443/TCP
maps.milestonesys.com
Allow when Milestone Map Service is enabled and used for Smart Maps.
Retrieves geographic map data for Smart Maps.
Outbound
Allow to the recording server addresses returned by the system.
Retrieves live and recorded video, audio, and metadata and performs supported PTZ and other media operations.
Outbound
22331/TCP
Allow to the configured event server.
Provides access to alarms, maps, configuration, status, actions, and related Event Server services.
Outbound
22332/TCP
Allow when the XProtect Smart Client uses event server REST or WebSocket interfaces directly.
Provides event and state subscriptions, events, alarms, and WebSocket messaging.
Management Client connects to the management server, API Gateway, recording server, event server, and Mobile Server to perform supported configuration and administration functions.
The exact connections required depend on the components and features administered from the client.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Outbound
Outbound
7563/TCP, or configured recording server URI
Retrieves video, audio, metadata, JPEG images, status information, and supported device data used during administration.
Outbound
Allow when Mobile Server administration uses the HTTP listener.
Supports applicable Mobile Server administration functions.
Outbound
Allow when Mobile Server administration uses the HTTPS listener.
Outbound
22331/TCP
Provides access to event server configuration, alarms, maps, status, actions, and related services.
Outbound
22332/TCP
Allow when the Management Client uses event server REST or WebSocket interfaces.
XProtect Mobile client connects to the Mobile Server by using the configured HTTP or HTTPS listener. The client does not connect directly to the recording server.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Outbound
Allow when the Mobile Server unsecured listener is enabled and used.
Supports login, client commands, and video and audio delivery.
Outbound
Allow when the Mobile Server secured listener is used.
Supports transport-secured login, client commands, and video and audio delivery.
XProtect Web Client connects to the Mobile Server by using the configured HTTP or HTTPS listener. The browser does not connect directly to the recording server.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Outbound
Outbound
Milestone Open Network Bridge authenticates through the Management Server and retrieves requested live and recorded media from the Recording Server .
ONVIF or RTSP clients initiate control connections to the bridge. If UDP media transport is negotiated, the bridge initiates RTP and RTCP traffic to the client-selected UDP ports.
Direction
Port / transport
Peer service
Firewall use
Purpose
Details
Inbound
554/TCP, configurable
Provides RTSP session control and optionally carries interleaved RTP and RTCP media.
Milestone Open Network Bridge computer listeners
Inbound
580/TCP, configurable
ONVIF clients
Allow from ONVIF clients that require bridge access.
Provides ONVIF authentication, control, configuration, PTZ, events, searches, and stream-URI requests.
Inbound
3702/UDP
WS-Discovery clients
Optional and disabled by default. Allow when WS-Discovery is enabled.
Enables ONVIF discovery.
Outbound
Configured Management Server URI/TCP, normally 80 or 443
Allow to the configured Management Server URI.
Supports authentication, service registration, configuration, and service discovery.
Outbound
Configured Recording Server URI/TCP, commonly 7563
Allow to the recording server addresses registered for the site.
Retrieves live and recorded video and supported audio for ONVIF or RTSP clients.
Outbound
Negotiated UDP port pairs
Client RTP and RTCP receivers
Allow when UDP media transport is negotiated.
Sends video and supported audio to the requesting client.
Firewall configuration considerations
Configure firewall access according to the installed components and enabled features in the deployment:
  • Allow inbound access only to listeners that are required.
  • Restrict source addresses to the computers, clients, integrations, or external systems that require access.
  • Do not expose local or same-computer service ports to other computers.
  • For configurable ports and destinations, use the values defined in the deployment configuration.
  • For third-party hardware devices, allow only the ports and protocols required by the device and consult the device manufacturer’s documentation.
Outbound connections are commonly permitted by default in Windows Firewall, but network firewalls and organizational security policies can require explicit outbound rules.
