[en] Use VictoriaLogs to view and investigate server logs
Versiune2026r1
LimbăRomână
[en] VictoriaLogs provides access to audit logs, system logs, and rule-triggered logs collected from across the XProtect system. Use the VictoriaLogs interface to search, filter, and investigate log data.
[en] Investigate log activity
[en] You can combine the time filter and search field to investigate specific events and activities in the system, for example:
  • [en] Review recent system activity
  • [en] Investigate user actions in audit logs
  • [en] Trace related events using a correlation ID
  • [en] Find activity related to a specific server, user, or resource
[en] Filter by time range
[en] Use the time filter at the top of the page to select the date and time range you want to view.
[en] Filter by column value
[en] Use the format:
[Column]:[Value]
[en] For columns that contain spaces, enclose the column name in quotation marks:
"Log type":System
[en] Search log entries
[en] Enter a query in the search field to filter the displayed log entries. Common examples:
[en] Task
[en] Query
[en] Show all logs
[en] Show only system logs
[en] "Log type":System
[en] Find entries containing a specific word, e.g. device
[en] Description:device
[en] Perform a case-insensitive search
[en] Description:i(device)
[en] Learn more
[en] VictoriaLogs supports additional query operators and advanced filtering capabilities. For more information, see the VictoriaLogs documentation.
