Analytics Events tab (options)
On the Analytics Events tab, you can enable and specify the analytics events feature.
Name | Description |
Enable | Specify if you want to use analytics events. As default, the feature is disabled. |
Port | Specify the port used by this feature. The default port is 9090. Make sure that relevant VCA tool providers also use this port number. If you change the port number, remember to change the port number of the providers. |
All network addresses or Specified network addresses | Specify if events from all IP addresses/hostnames are allowed, or only events from IP addresses/hostnames that are specified in the Address list (see below). |
Address list | Specify a list of trusted IP addresses/hostnames. The list filters incoming data so that only events from certain IP addresses/hostnames are allowed. You can use both Domain Name System (DNS), IPv4 and IPv6 address formats. You can add addresses to your list by manually entering each IP address or host name, or by importing an external list of addresses.
