Access Control Settings tab (options)
Note
The use of XProtect Access requires that you have purchased a base license that allows you to access this feature.
Name | Description |
Show development property panel | If selected, additional developer information appears for Access Control > General Settings. This setting is only meant to be used by developers of access control system integrations. |
