System settings (Options dialog box)
Version2026r1
LanguageEnglish
In the Options dialog box, you can specify a number of settings related to the general appearance and functionality of the system.
Available functionality depends on the system you are using. See the complete feature list, which is available on the product overview page on the Milestone website (https://www.milestonesys.com/products/xprotect-compare-variants/).
To access the dialog box, select Tools > Options.
General tab opened from the Options dialog box.
