Record tab (devices)
The following devices have a Record tab:
  • Cameras
  • Microphones
  • Speakers
  • Metadata
Recordings from a device are only saved in the database when you have enabled recording and the recording-related rule criteria are met.
Parameters that cannot be configured for a device are grayed out.
Record tab overview for a selected device.
Tasks on the Record tab
Name
Description
Recording
Enable/disable recording
Enable recording on related devices
Pre-buffer
Pre-buffering and storage of recordings
Manage pre-buffering
Manage manual recording
Recording frame rate
Specify recording frame rate
Enable keyframe recording
Storage
Monitor the status of databases for devices
Select
Move devices from one storage to another
Delete All Recordings
Use this button if you have added all devices in the group to the same server:
Delete recordings
Automatically retrieve remote recordings when connection is restored
Save and retrieve remote recording
