Streams tab (devices)
The following devices have a Streams tab:
  • Cameras
The Streams tab lists by default a single stream. It is the selected camera's default stream, used for live and recorded video. If you use adaptive playback, two streams must be created.
Streams tab overview for a selected device.
Tasks on the Streams tab
Name
Description
Add
Click to add a stream to the list.
Add a stream
