Enable/disable recording
Recording is by default enabled. To enable/disable recording:
  1. In the Site Navigation pane, select Recording Servers.
  2. Select the relevant device in the Overview pane.
  3. On the Record tab, select or clear the Recording check box.
Note
You must enable recording for the device before you can record data from the camera. A rule that specifies the circumstances for a device to record does not work if you have disabled recording for the device.
