Patrolling tab (devices)
The following devices have a Patrolling tab:
  • PTZ cameras
On the Patrolling tab, you can create patrolling profiles - the automatic movement of a PTZ (pan-tilt-zoom) camera between a number of preset positions.
Before you can work with patrolling, you must specify at least two preset positions for the camera in the Presets tab, see Add a preset position (type 1).
Patrolling tab, displaying a patrolling profile with customized transitions:
Patrolling tab overview for a selected device.
Tasks on the Patrolling tab
Name
Description
Add
Add a patrolling profile
Preset ID
Specify preset positions in a patrolling profile
Wait time (sec)
Specify the time at each preset position
Customize transitions
Customize transitions (PTZ)
Go to specific position on finish
Specify an end position when patrolling
Manual patrolling
Monitor if the system is currently patrolling or a user has taken control.
Start and Stop
Use the Start and Stop buttons to initiate and stop manual patrolling.
See Specify PTZ session timeouts for information about how to specify how much time should pass before regular patrolling is resumed for all or for individual PTZ cameras.
Manual patrolling properties
The Manual patrolling table shows the current status of the PTZ camera.
Name
Description
User
Displays the user who has either reserved the PTZ session or started a manual patrolling and currently controls the camera.
If a patrolling session is activated by the system, it displays Patrolling.
Priority
Displays the user's PTZ priority. You can only take over PTZ sessions from users or patrolling profiles with a lower priority than yours.
Timeout
Displays the remaining time of the current reserved or manual PTZ sessions.
Reserved
Indicates if the current session is a reserved PTZ session or not.
  • True: Reserved
  • False: Not reserved
