Specify the time at each preset position
When patrolling, the PTZ camera by default remains for 5 seconds at each preset position specified in the patrolling profile.
To change the number of seconds:
  1. In the Site Navigation pane, select Devices and then select Cameras.
  2. Select the relevant PTZ camera in the Overview pane.
  3. On the Patrolling tab, select the patrolling profile in the Profile list.
  4. Select the preset position for which you want to change the time:
    Example of a selected preset position for a patrolling profile.
  5. Specify the time in the Time on position (sec) field.
  6. If required, repeat for other preset positions.
