Important notes about connection settings
The Use HTTPS option does not affect the connection
The port number does not affect the connection.
Communication with Axis devices is always secured, as all connections are established through Axis Cloud Connect.
A constant connection to the cloud is required. If Axis Cloud is not accessible, the Axis Cloud-connected devices will appear offline.
Devices onboarded through Axis Cloud Access use cloud‑based hostnames, which always start with AxisCloud….
These settings are handled automatically and do not require manual configuration.
