XProtect Axis Cloud Access for operators
How to interpret the metadata indicators
Version1.1.21
LanguageEnglish
  • If you see only the three blue cube icons, metadata is configured, but no metadata is currently flowing.
  • When metadata is being received, the numeric indicators above the blue cubes appear and animate (the numbers show and disappear repeatedly).
  • This animation indicates active metadata flow.
Note
Metadata does not appear as video. Its presence is confirmed by the animated indicators.
If no metadata entry appears, verify that:
  • The device is successfully onboarded
  • MQTT is connected to the device
  • Metadata topics are configured on the device (if required)
