XProtect Access for users
Show or hide access control unit information on a smart map
You can show or hide information about acccess control units on a smart map. This is useful, for example, when you want to increase or reduce the amount of content on your smart map.
  1. Select the view that contains the smart map that you want to work with.
  2. Click Show or hide layers and custom overlays.
  3. Select or clear the check boxes for the access control unit information to show or hide.
