XProtect Access for users
Remove an access control unit from a smart map
You can remove devices, for example if devices have been physically removed or were added by mistake. By removing a device, the positioning information of the device, for example the geo coordinates, are removed from your VMS system.
To remove access control units, this Access Control permission must be enabled in XProtect Smart Client:
  • Edit
Steps:
  1. Select the view that contains the smart map, and then click Setup.
  2. To remove a single device, right-click the device and click Remove access control unit.
