Add access control units to buildings
After creating a building and adding levels, you can add access control units to the building. If you've specified a default level, the access control units are associated with it. If not, the access control units are associated with the first level. You can change the level and associate the access control unit with any of the levels in the building.
Steps:
Go to the building on your smart map. Zoom in if needed.
On the workspace toolbar, select Setup.
Click on the building to see the building levels.
Select the level to which you want to add your access control unit.
To associate the access control unit with one or more levels, right-click the unit, click Access control unit visible on level, then select the required levels.
Select Setup again to exit setup mode and save your changes.
If you haven't selected any level, the access control unit is visible on all levels.
