XProtect Access for users
Add an access control unit to a smart map
You can add access control units to a smart map in their actual positions in your environment. This gives you a good overview of your surveillance system, and can help you respond to a situation.
If the geo-coordinates of the access control unit have been specified in XProtect Management Client by your system administrator, the access control unit will automatically be positioned on the smart map. If not, you must position the unit yourself in its exact geographic location.
  1. Select the view that contains the smart map, and then click Setup.
  2. On the smart map, click SC_MapS_AddAccessUnit_icon.jpg to open the list of connected access control systems and access control units.
  3. Drag an access control unit to the smart map. You can then adjust the position, if needed.
  4. To save the change, click Setup to exit setup mode.
