Using access control with smart maps
Smart Maps in the Milestone XProtect VMS display an interactive, real-time view of your organization's locations. Smart Maps display cameras, alarms, access control units, and other devices on a digital map of your locations to make it easier for you to monitor and respond to incidents.
You can use a smart map with your access control system to:
Get an advanced overview of your locations: with all access control units mapped out on the smart map, you can quickly identify and address potential issues.
Get visual feedback right away: when an event occurs, the door icon changes and when an alarm is triggered, the smart map shows the exact location of the alarm.
Work with access control units directly on the smart map: adjust, lock or unlock access control units, acknowledge alarms, and carry out other tasks directly from the map interface.
Monitor locations from a central view: manage multiple locations from a single map. Smart maps combine your security operations across locations into one view to help you carry out your work more efficiently.
