XProtect Manager Plug-in
Opening or decrypting a Case-Pak
Version2.1
LanguageEnglish
Opening a Case-Pak in Data Central. Once you receive the encrypted Case-Pak, you simply drag and drop the icon anywhere into the software interface. It will ask you for the password (if there is one) and then open the Import Case window.
A
Case-Pak import location
You have two options. If you select “New case,” you will be given the option to create the case number. If you select “Existing case,” you will be presented with a dropdown and a current list of open cases.
B
Information to import
If the sender of the Case-Pak included the “Case information” and the “File notes,” you can opt to bring that information into the case.
C
Path
This is the location where you would like the decrypted files to be placed once Data Central is complete.
