XProtect Manager Plug-in
Data Central
Version2.1
LanguageEnglish
Data Central is an open middleware platform for evidence handling. It provides consistent operator flow across all case creation and desired workflows, via integrations with other best-of-breed third-party software.
Within the User Interface (UI), you can create cases, drag and drop files/folders into specific locations, have your proprietary video automatically converted to standard .mp4 files, search through all of the files within the case, add file notes to individual files, and send files to specific workflows such as DVD burning, transcription services, and analytics. Once the case is ready, the contents can be encrypted into a Case-Pak with each file being hashed and all the metadata included. Alternatively, the case can be sent to a backend Digital Evidence Management Solution, Case Management Solution, or Records Management Solution.
