XProtect Manager Plug-in
Using the XProtect Evidence Plug-in
Version2.1
LanguageEnglish
Starting and logging into the XProtect Evidence Plug-in
To use the XProtect Evidence Plug-in, start the XProtect Smart Client and select the Evidence tab.
Closing the XProtect Evidence Plug-in
When you close the XProtect Smart Client, the XProtect Evidence Plug-in closes as well. Unfinished jobs continue to run server-side.
Note
As long as you press the Submit All button, your jobs are created and handled without additional user intervention, regardless of whether the XProtect Smart Client is open. If you are in the middle of creating a job and you go to a different tab (i.e., Exports) without pressing the Submit button, you will lose your metadata and camera requests.
The camera tree view
You can select the cameras you want to view from the camera tree view.
  • Click a camera to open it in review mode within the video canvas.
  • Use the search function to find the camera you need. Start typing the name of your camera, and it filters out the cameras based on your search. It is a great tool when you have hundreds of cameras.
The canvas
On the canvas, you can view video and control event dates/times.
UI components
Description
Timeline
Shows you the length of the video file you’re viewing and the specific time in the video during playback.
Slider bar
Shows the time frame within the video viewed, reflected on the left of the timeline. If you drag the slider bar forward or backward, the video will fast-forward or rewind.
Player controls
Enables you to play, pause, or stop the video.
Set event times
Use these controls to create the start and end date and time. It shows you the duration you have selected.
To move the camera with the chosen event duration and list it in the Camera Request pane, click the Add to List button.
NOTE: When you select your second/next camera, the event time will stay the same as the previous camera. If you click the Add to List button, the camera is moved to the Camera Request pane with the same event time. If you want to change the event time, you can make the relevant changes and click the Add to List button again.
The Information pane
The Information pane displays the configured metaform, allowing you to enter metadata related to the case. The fields can be configured as optional or required, choice/dropdown, or short or long text.
The Camera Request pane
The Camera Request pane lists all the cameras and event times associated with each request.
If you click the Submit All button, all the metadata and the camera requests are sent to your configured backend of choice. When you select it, the job/upload will be run automatically from the service.
