Milestone CCure 9000 Video Push (CC9KVP)
Feature list
Video feature
Mark an “X” where comply
Special notes
CCure min. version supported
Live video
X
2.70
Text overlay
Not supported
Pre-recorded video playback
X
2.70
Status
X
2.70
Export to AVI
Not supported
Time synchronization
X
2.70
Record start (on demand)
Not supported
CCure journal entry "bookmark" is created. Recording not triggered in XProtect.
Frame rate definition
Not supported.
Configurable in XProtect system.
Record stop (on demand)
Not supported.
PTZ (domes only)
X
2.70
Video alarms
X
Video loss, motion, recording events in this version.
2.70
Video tour
X
2.70
Video view up to 16 cameras
X
2.70
Presets & patterns
X (only presets)
(patterns not supported)
2.70
View live & recorded video from more than one camera via popup in single window
Supported with live video. Not supported with recorded video.
With recorded video more than one single window can run at the same time.
2.70
PTZ presets & presets based on event, alarm input
Supported (only presets)
2.70
Replay up to 4 cameras for same time interval
Not supported.
Playback from 1 camera only with single command.
Toggle video window size from 1X to 4X
X
2.70
Display up to 4 live video windows based on event
X
Use views for this.
2.70
Original recorded video is secured
X
2.70
Playback and recorded video in one window
Not supported.
Bi-directional actions
X
2.70
Support for all camera and recorder events in CCure
X
2.70
Support for XProtect custom events in CCure
X
2.70
Support for XProtect analytic events
X
2.70
Support for XProtect alarm acknowledgment
X
2.70
CCure Enterprise: Master Application Server (MAS)/Satellite Application Server (SAS)
X
Please see Configuring CCure 9000 Enterprise MAS/SAS scenario
2.70
Support for Milestone XProtect Recording Server data encryption
X
Please see Integration limitations
2.70
Support for connecting between XProtect and CCure using certificate based encryption.
X
Authentication supported between XProtect and CCure on both port 443 and 80.
X
Parameters for XProtect VMS connection supports using IP address and hostname.
X
