Integration components
The administration and configuration of the integration takes place in the CCure Administration Station and Server Configuration Applications.
The solution requires that:
Integration server components are installed on the CCure server.
Integration client components are installed on all required CCure client machines.
The Milestone MIPSDK x86 redistributable is installed on all client machines.
If you remove earlier versions of the Milestone integration, you will not remove Milestone objects from Cross Fire database.
This integration uses the same Milestone objects from earlier versions of the integration. When you upgrade, all Milestone video servers and cameras set up with earlier versions of the integration will continue to exist.
