Feature list
Video feature | Mark an “X” where comply | Special notes | CCure min. version supported |
Live video | X | 2.70 | |
Text overlay | Not supported | - | |
Pre-recorded video playback | X | 2.70 | |
Status | X | 2.70 | |
Export to AVI | Not supported | - | |
Time synchronization | X | 2.70 | |
Record start (on demand) | Not supported | CCure journal entry "bookmark" is created. Recording not triggered in XProtect. | - |
Frame rate definition | Not supported. | Configurable in XProtect system. | - |
Record stop (on demand) | Not supported. | - | |
PTZ (domes only) | X | 2.70 | |
Video alarms | X | Video loss, motion, recording events in this version. | 2.70 |
Video tour | X | 2.70 | |
Video view up to 16 cameras | X | 2.70 | |
Presets & patterns | X (only presets) | (patterns not supported) | 2.70 |
View live & recorded video from more than one camera via popup in single window | Supported with live video. Not supported with recorded video. | With recorded video more than one single window can run at the same time. | 2.70 |
PTZ presets & presets based on event, alarm input | Supported (only presets) | (patterns not supported) | 2.70 |
Replay up to 4 cameras for same time interval | Not supported. | Playback from 1 camera only with single command. | - |
Toggle video window size from 1X to 4X | X | 2.70 | |
Display up to 4 live video windows based on event | X | Use views for this. | 2.70 |
Original recorded video is secured | X | 2.70 | |
Playback and recorded video in one window | Not supported. | - | |
Bi-directional actions | X | 2.70 | |
Support for all camera and recorder events in CCure | X | 2.70 | |
Support for XProtect custom events in CCure | X | 2.70 | |
Support for XProtect analytic events | X | 2.70 | |
Support for XProtect alarm acknowledgment | X | 2.70 | |
CCure Enterprise: Master Application Server (MAS)/Satellite Application Server (SAS) | X | Please see Configuring CCure 9000 Enterprise MAS/SAS scenario | 2.70 |
Support for Milestone XProtect Recording Server data encryption | X | Please see Integration limitations | 2.70 |
Support for connecting between XProtect and CCure using certificate based encryption. | X | ||
Authentication supported between XProtect and CCure on both port 443 and 80. | X | ||
Parameters for XProtect VMS connection supports using IP address and hostname. | X |
