Configuring cameras for LPR
These are the steps to go through when you add and configure cameras used with XProtect LPR.
Requirements for LPR in the Management Client
Once cameras have been mounted and added in the Management Client, adjust each camera's settings so that they match the requirements for LPR. You adjust camera settings on the properties tabs for each camera device.
For the relevant cameras, Milestone recommends to:
  • Set the video codec to H.264
    For LPR use, JPEG is not recommended and H.265 is not supported. Disadvantages of using other codecs include delays in stream processing and unnecessary extra CPU load on the server. For this reason, Milestone recommends that you always use H.264 video streams for LPR cameras.
  • Specify a frame rate of four frames per second
  • Avoid compression, so set a fine quality
  • If possible, specify a resolution below one megapixel
  • If possible, keep automatic sharpness at a low level
To learn about LPR fundamentals, make yourself familiar with the information in ナンバープレート認識用カメラの準備.
Snapshots (explained)
The system uses snapshots to optimize the configuration automatically and to visualize the effect of the recognition settings as they are applied.
You need to provide at least one valid snapshot in order to complete the initial configuration of a camera.
As a guideline, capture snapshots of vehicles in the real physical surroundings and conditions, in which you want to be able to recognize license plates.
The list below illustrates examples of the situations that you should consider when you capture and select snapshots. Not all may be applicable to your surroundings.
Milestone recommends that you select minimum 5-10 snapshots that represent typical conditions of:
    The weather; for example, sunlight and rain
Examples of weather conditions to consider when you capture and select snapshots.
    The light; for example, daylight and nighttime
Examples of light conditions to consider when you capture and select snapshots.
    Vehicle types; to define the top and bottom of the recognition area
Examples of top and bottom of the recognition area to be considered when you capture and select snapshots.
    Position in the lane; to define the left and right of the recognition area
Examples of left and right of the recognition area to be considered when you capture and select snapshots.
    Distance to the car; to define the area where LPR analyzes license plates
Examples of distance to the area where LPR analyzes license plates when you capture and select snapshots.
Add LPR camera
To configure cameras for LPR, you initially run the Add LPR camera wizard. The wizard takes you through the main configuration steps and automatically optimizes the configuration.
To run the wizard:
  1. In the Site Navigation pane, select Servers > LPR servers > LPR cameras.
  2. Right-click the server and select Add LPR camera.
  3. Follow the instructions in the wizard:
    • Select the camera you want to configure for LPR
    • Select which country modules you want to use with your LPR camera (see Country modules tab)
    • Select snapshots to use for validating the configuration (see Snapshots (explained))
    • Validate the result of the snapshot analysis (see Validate configuration)
    • Select which match lists to use (see Match lists). Choose the default selection, if you have not yet created any lists
  4. On the last page, click Close.
    The LPR camera appears in the Management Client and based on your selections, the system has optimized the recognition settings for the camera (see Add LPR camera).
  5. Select the camera you have added and review its settings. You only need to change the configuration if the system does not recognize license plates as well as expected.
  6. In the Recognition settings tab, click Validate configuration (see Validate configuration).
Adjust settings for your LPR camera
The system automatically optimized the configuration of your LPR camera, when you added the LPR camera with the Add LPR camera wizard. If you want to make changes to the initial configuration, you can:
Info tab
This tab provides information about the selected camera:
Name
Description
Enable
LPR cameras are by default enabled after the initial configuration. Disable any camera that is not used in connection with LPR.
Disabling an LPR camera does not stop it from performing normal recording in the surveillance system.
Camera
Shows the name of the selected camera as it appears in the XProtect Management Client and the clients.
Description
Use this field to enter a description (optional).
Change Server
Click to change LPR server.
Changing the LPR server can be a good idea if you need to load balance. For example, if the CPU load is too high on an LPR server, Milestone recommends that you move one or more LPR cameras to another LPR server.
Change recognition settings manually. Based on the snapshots you provided, the system auto-configured the recognition settings. Changing these settings can greatly affect the recognition success rate.
Action buttons
Change, update, and validate auto-configured settings.
Name
Description
Test that license plates are recognized as expected (see Validate configuration).
Auto-configure
Discard manual changes and auto-configure settings (see Auto-configure).
Snapshots
Add or delete snapshots (see Select snapshots).
Recognition area
To ensure best performance and avoid false recognitions, Milestone recommends that you select a clearly defined and "well-trimmed" recognition area. The area should cover only the part of the image where the license plate is visible and remains visible as the vehicle moves in and out of the image. Avoid irrelevant moving objects (people, trees, traffic) in the recognition area (see カメラの位置決め).
License plates are not recognized in the red area.
The Recognition area settings in the Properties window for LPR cameras.
When specifying a recognition area, you can click:
  • Clear to remove all selections and select new areas for LPR
  • Undo to revert to your last saved recognition area
After changing the settings for your LPR camera, validate your configuration (see Validate configuration) to check if the system recognizes license plates as well as expected.
Character height
Define the minimum and maximum height of the license plate characters (in percent). Select character heights as close as possible to the height of the characters in the real license plate.
These character settings affect the recognition time and process. The smaller the difference between the minimum and the maximum character height:
  • The smoother the LPR process
  • The lower the CPU load
  • The sooner you get the results
The Character height settings in the Properties window for LPR cameras.
The overlay in the snapshot displays the currently defined character height setting. The overlay grows and shrinks proportionally to the character height settings to the right. For easy comparison, drag the overlay on top of the real license plate in the snapshot. Zoom with your mouse wheel for a closer look.
Name
Description
Minimum height
Set the minimum character height for including license plates in the recognition process. If the real license plate characters are smaller than the value you specify, the system will not start the recognition process.
Maximum height
Set the maximum character height for including license plates in the recognition process. If the real license plate characters are bigger than the value you specify, the system will not start the recognition process.
Advanced settings
The recognition process has two steps: 1) finding the plate(s) and 2) recognizing the characters in the plates. Click Advanced settings to define a trade-off between processing speed and recognition quality.
High recognition quality:
  • Needs higher computational effort
  • Increases CPU load
  • Takes more time to return results
The Advanced settings in the Properties window for LPR cameras.
When the optimal results are met, the recognition process stops and returns the license plate it recognized at that point.
Name
Description
Compensate for interlacing
If your LPR camera records interlaced video, and you see a combing effect in the de-interlaced image in LPR, select this check box. This may improve image quality and recognition results.
Maximum number of frames processed per second
Limit the number of frames your system processes every second. If you keep this setting low, you can increase the frame rate on your camera without adding unnecessary load to your LPR server.
Unrestricted: Remove the top limit. You will risk increasing the processing time and the CPU load.
Maximum number of seconds used per frame
Limit the number of seconds your LPR can spend on recognizing one frame. If adjusted, the recommended value is 0.2 seconds per frame.
Unlimited: Remove the top limit. You will risk increasing the processing time and the CPU load.
Stop recognition above
Stop recognition when a license plate is recognized with a confidence level equal to or above the value you specify.
Discard recognitions below
Discard recognitions with a confidence level below the value you specify. Increase this value to get fewer but possibly more accurate recognitions. Decrease this value to get more but potentially less accurate recognitions.
The smaller the difference between Stop recognition above and Discard recognitions below values, the lower the processing time and the CPU load.
Maximum number of license plates recognized per frame
Recognize several license plates simultaneously. For example, relevant for cameras recording multi-lane roads, where many license plates must be recognized at the same time.
Time span in seconds for avoiding partial recognitions
Delay all recognitions for the time period you specify. This is to avoid that the same license plate is recognized several times as different license plates. The system will wait for a better recognition and only accept the most complete recognition.
Before changing this setting, ensure no irrelevant moving objects (see カメラの角度) block the view of your LPR camera.
Match lists tab
On this tab, select which match list(s) you want a specific LPR camera to match license plates against. You can create as many lists as you need (see Add new match lists).
The settings for match lists in the Properties window for LPR cameras.
Name
Description
All
License plates are matched against all available and future lists.
Selected
License plates are matched against the selected lists only. Select one or more from the available lists.
Country modules tab
国モジュールによって、ナンバープレートの外観と構造に基づき、どのナンバープレートがどの国、州、地域のものかをシステムが把握できるようになります。
On this tab, select the country modules that you want to use with a specific LPR camera. The list that you can select from depends on:
Milestoneは、カメラ1台につき最大5つの国モジュールを追加することを推奨しています。
Already licensed modules appear with a check mark in the Licensed column. If the country module you are looking for is not on your list, contact your vendor.
The Country module settings in the Properties window for LPR cameras.
Name
Description
Select
Click to select or deselect a country module. The list of selected country modules on the right-hand side updates automatically.
Country Module
Lists the installed country modules.
Country Code
Letters that identify a country module.
Licensed
Shows if a country module is already licensed. You can select a licensed country module for as many cameras as you like.
Extend time span for avoiding partial recognitions
If parts of the same license plate are recognized as separate and incomplete plate numbers, ensure no irrelevant moving objects (see カメラの角度) block the view of your LPR camera. If the problem persists, give the system more time to avoid partial recognitions. Your recognitions will be more accurate, but they will all show up delayed.
  2. In the LPR cameras pane, find and click the camera to modify.
  3. On the Recognition settings tab, click Advanced settings.
  4. In the Time span for avoiding partial recognitions field, drag the slider to the right to give the system a maximum of five extra seconds to recognize the most complete license plate numbers and discard the rest.
Select snapshots
When you configured the LPR initially with the Add LPR camera wizard, you also added snapshots (see Snapshots (explained)). You can always add additional representative snapshots to improve the optimization of the configuration.
  1. Select the relevant camera.
  2. In the Recognition settings tab, click Snapshots.
  3. Capture snapshots from live video or import them from an external location. Click Next.
    The system analyzes the snapshots you have selected for the camera.
  4. On the next page, approve or reject each of the snapshots. If the system could not recognize any license plates, click Previous to add new snapshots in a better quality. If the system still cannot provide correct recognitions, you probably need to change your configuration. Check that the camera is mounted and configured correctly (see ナンバープレート認識用カメラの準備).
  5. When you have approved all snapshots, click Next and close the wizard.
  6. On the Recognition settings tab, click Validate configuration (see Validate configuration).
You can validate your current configuration to see if you need to change any settings or provide more snapshots. The validation function informs you about how many license plates your system recognizes, and if they are recognized correctly.
It can help you decide if your confidence level is set correctly and if your system configuration is optimal.
  2. From the Recognition settings tab, click Validate configuration.
    Based on the current settings, the system analyzes the snapshots you have selected for the camera and provides a result summary:
    • Registration number: License plate number
    • Country Code: Letters that identify a country module
    • Character height: 9.5%
    • Confidence level: The percentage of confidence with which the license plates have been recognized
    • Processing time: The time it took to analyze a snapshot and return a reading measured in ms
    • License plates style: A set of characteristics of a license plate. See License plate styles and aliases
    • License plates style alias: A more user friendly name to identify the style. See Aliases
      Example of a result summary for validation of recognition settings for LPR cameras.
  3. If the current configuration meets your requirements, click Close.
  4. If you want to investigate the results further, click Next, and you can review the results for each snapshot. This helps you to identify the situations that cause problems.
You can validate the configuration as many times as you like and on any LPR camera and with different settings.
Auto-configure
Auto-configuration of the LPR camera overwrites any manual changes you have made to the settings. You can select this option if, for example, you have made manual changes that have not given you good recognition results.
  1. From the Recognition settings tab, click Auto-configure.
    A new dialog box appears.
  2. Confirm that you want to return to auto-configured settings by clicking Next.
    The system optimizes the settings.
  3. Click Close.
  4. If prompted, confirm to save the configuration.
  5. Review and validate (see Validate configuration) the new settings.
