Layers on smart map
You can turn layers on and off on your smart map depending on what you want to see.
A smart map has multiple layers. Each layer contains different elements.
You can hide the elements on a smart map layer. This feature is useful when you want to focus on a specific element or simplify the display on the smart map.
Layer Elements
System elements Cameras, access control units, and other devices. Links and locations.
Custom overlays Bitmap images, CAD drawings, and shapefiles.
Geographic backgrounds The basic world map or one of the following services:
  • Bing Maps
  • Google Maps
  • Milestone Map Service
  • OpenStreetMap
Bing Maps and Google Maps are available as geographic backgrounds only if your system administrator has enabled them in XProtect Management Client. For more information, see Geographic backgrounds.
