Geographic backgrounds
You can use the following services as the geographic backgrounds of your smart map A map functionality that uses a geographic information system to visualize devices (for example, cameras and microphones), structures, and topographical elements of a surveillance system in geographically accurate, real-world imagery. Maps that use elements of this functionality are called smart maps.:
Bing Maps
Google Maps
Milestone Map Service
OpenStreetMap
After you have selected the geographic background, you can add the devices, for example cameras, and custom overlays, for example shapefiles. For more information, see Custom overlays.
