Recordings from multiple cameras (explained)
You can play back recordings from multiple cameras on both the Views tab and the Investigations tab.
On the Views tab:
- In the Views pane section, go to a folder with views and click the relevant view. The video starts playing in live mode.
- On the timeline, click Playback for the timeline in playback mode to show up (see Using the timeline in playback mode (explained)).
In the view of multiple cameras:
- See recordings from all cameras in the view.
- See which of the cameras have microphones attached.
- See which of the cameras have speakers.
- Click a camera to view a recording from that camera only. To go back to the view with all cameras, click Back to view.
On the view toolbar:
- If you want to use the entire screen of your computer when presenting cameras in a view, click
to open the Grid view.
On the Investigations tab, you can play back recordings without creating an investigation.
In this mode, you can:
- Choose the cameras that you want to play back and remove those cameras that do not have recordings for the specified time (see Remove unnecessary cameras from video playback).
- Specify the time of the recordings that you want to play back (see Specify time for video playback).
- Specify the start and end time for the recordings (see Using the timeline in investigations (explained)).
- Play back the recordings from all cameras in the selected camera group at the same time.
- Start or stop playing audio with the video recording from a specific camera in the selected camera group (see Playing back audio in video recordings (explained)).
