Sound Settings (Alarms node)
When you configure sound settings, specify the following:
Name |
Description |
Sounds |
Select the sound to be associated with the alarm. The list of sounds contains a number of default Windows sounds. You can also add new sounds (.wav or .mp3). |
Add |
Add sounds. Browse the sound file and upload one or several .wav or .mp3 files. |
Remove |
Remove a selected sound from the list of manually added sounds. Default sounds cannot be removed. |
Test |
Test the sound. In the list, select the sound. The sound plays once. |
