Cameras (Devices node)
Camera devices are added automatically when you add hardware to the system and are by default enabled.
The system comes with a default start feed rule which ensures that video feeds from all connected cameras are automatically fed to the system. The default rule can be deactivated and/or modified as required.
Follow this configuration order to complete the most typical tasks related to configuration of a camera device:
- Configure camera settings, see Settings tab (devices.
- Configure streams, see Streams tab (devices).
- Configure motion, see Motion tab (devices).
- Configure recording, see Record tab (devices) and Monitor the databases for devices.
- Configure the remaining settings as needed.
