Delete floor plans on levels (smart map)
If a floor plan on a level inside a building has changed, you may need to replace the custom overlay illustrating the floor plan. Milestone recommends that you delete the old floor plan, before adding a new one.
Smart map editing has been enabled on your Smart Client profile in XProtect Management Client.
Steps:
- Navigate to the building on your smart map. If necessary, zoom in.
- Select the building. A pane appears on the right-hand side showing you the levels of the building.
- On the workspace toolbar, select Setup.
- Select the level where the custom overlay is.
- Right-click anywhere on the custom overlay and select Delete custom overlay.
- Select Setup again to exit setup mode and save your changes.
To edit the position or size of the floor plan, right-click the custom overlay and select Edit position. Now you can move, rotate, and change the size of the custom overlay.
