Change order of levels in buildings (smart map)
Smart map editing has been enabled on your Smart Client profile in XProtect Management Client.
Steps:
- Navigate to the building on your smart map. If necessary, zoom in.
- Select the building. A pane appears on the right-hand side showing you the levels of the building.
- On the workspace toolbar, select Setup.
- Click and drag the dotted area
to the correct position. Any associated devices and custom overlays stay with the level. - Select Setup again to exit setup mode and save your changes.
