Enter default credentials
Once you have launched Milestone Software Manager, before you can start working, you must enter default credentials for the remote computers on the network.
  1. Launch Milestone Software Manager. A Default Credentials window appears.
  2. Fill in the default login credentials. These are used as default login when working with remote computers on your network (and no other or specific credentials are specified for a computer).
  3. If you need to change default credentials at a later time, go to Options > Change default credentials.
  4. If needed, you can later specify individual credentials (see More server options) on each remote computer.
This has nothing to do with accessing Milestone Software Manager itself. It is strictly a matter of specifying default credentials for relevant remote computers on the network (where no other or specific credentials have been specified).
