BriefCam User Guide
Dwell Heat Map
Version2025r1
LanguageEnglish
To generate a dwell heat map:
  1. Click the Visual Layers control (Visual layers icon.png).
  2. Click the Dwell icon (Dwell icon.png) to display a dwell heat map layer highlighting area, in which events lingered for extended periods of time (see below). The minimum time an object needs to dwell in order to appear in the Dwell heat map layer is 10 seconds.
The dwell heat map legend (Dwell heat map legend.png) available at the bottom of the synopsis playback window indicates the number of detected objects having dwelled at the highlighted areas.
