Activity Heat Map
To generate an activity heat map:
Click the Visual Layers control (
Click the Activity icon (
) to display an activity heat map layer, which highlights areas in which increased event movement has been detected (see below).
The activity heat map legend (
) available at the bottom of the synopsis playback window indicates the number of detected objects associated with each of the various heat map colors.
