BriefCam User Guide
Creating an Airplane Counting Rule
Version2025 R1
LanguageEnglish
When using the Next-Gen engine, you can set a rule to count airplanes.
To count airplanes:
  1. Select the Count filter and then Airplane Counting.
  2. Select either the Above or the Below checkbox.
  3. Set the number of airplanes in the selected checkbox.
  4. Click APPLY.
